12-16-2023 03:49 AM - last edited on 12-18-2023 03:56 PM by Kristoff
Just got a Canon Ivy 2 mini printer. Couple things I can't figure out. When I tap on filters, I don't get any options. It just shows a circle with a line through it and says "none". The filter option is greyed out and says none when you tap on it. The 2nd thing is the I choose text color it doesn't seem to work. Text is still just black. What am I doing wrong? Haven't tried to print yet. Thanks,
Running on Android (Version 13)
12-16-2023 08:14 AM
Thanks for joining the conversation, BAT!
So that the Community can help you better, we need to know exactly which operating system is running on your mobile device (i.e. Android or iOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
12-16-2023 11:23 AM
The phone operating system is Android version 13. The app used is Canon Mini Print (USA). Problem 1: "Filters not functioning. Click photo Album. Add a Photo. Tap on filters. The only option after tapping filters is "None". I see a non-tapable (greyed out) circle with a line through it diagonally and below that it says "none". There are no filter options to choose. Problem 2: Adding text. I can add text with no problem; but when I tap on a color, to change the color of the text; it still shows on the screen as black text with a white ouline. Thanks,
12-23-2023 06:52 PM
Hello, I still need help. I haven't found a solution. Thanks,
