ImageProGraf Pro-1100 Which Driver?
J03_D4ncer
Enthusiast
There is Master Setup mms2-mac-103_0_1-ea21_3.dmg located on Canon's support page and there is
mms2-mac-103_10_0-ea21_3 located on ij.start.canon/connect. What's the difference between the two?
Here's what I had to do. I installed PRO-1100 CUPS Printer Driver Ver.29.1.0.0 (Mac). After installation was completed, I went to Apple System Settings\Printers and Scanners and added the Pro-1100. I highlighted Canon PRO-1100 series Bonjour. In the Use drop down menu, I chose Select Software. In the Select Software dialog box, I chose Canon PRO-1100 series. Done. The driver version is Canon PRO -1100 series version 29.1.0.0. I bypassed AirPrint altogether.
6 REPLIES 6
J03_D4ncer
Enthusiast
I'm experiencing difficulty installing the driver. I read somewhere that one shouldn't use Air Printer to install the imageprograf driver. Yet, when I access Printers & Scanners, under kind I see Canon Pro-1100 series AirPrint. I used the master setup from ij.start.canon/connect
I'm using an ethernet connection instead of wi-fi. I seem to be stuck on the Add Printer page of Master Setup. The response is I didn't install the driver. What am I doing wrong?
J03_D4ncer
Enthusiast
To get past it, I skipped it.
Welcome to the Canon Forums!
The Forums aren't intended for immediate assistance. If your question is of an urgent nature,click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside of the USA, please click HERE to find your support options.
You should download this driver and then Add Printer in the Printers and Scanners section. Wait, maybe several minutes, for the Canon IJ Series printer to appear. The AirPrint version may appear first; keep waiting.
Thank you.
