ImageClass mf236n Scans But Won't Print
enteng000
I have an ImageClass mf236n that was working fine up until 2 or 3 days ago (around 8/17/23).  It stopped scanning and printing completely, spitting out an error: "Cannot communicate with the device.  The cable may be disconnected, or the device may be turned off.  Check the device status and try again.  Scanner driver will be terminated.  Code: 155,0,0".
In troubleshooting, I reinstalled the latest drivers and utility software (winmfscanutilityv12101) from the Canon web site with no success.  I replaced the USB cable twice but still the same behavior.  I then installed an older version of the software (winmfscanutilityv12004) and voila, the scanning functionality worked even with the old cable.  However, I found out later that the print functionality no longer works.  The printer is unresponsive to print commands, and the print queue doesn't show anything.  I've reinstalled the latest drivers.  Would appreciate any assistance.
3 REPLIES 3
Hector
Hello,
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance. For a more immediate resolution, you can contact support over the phone at 1-800-652-2666.
  1. What version of the Windows operating system are you using on your computer?
  2. When you attempt to print from the computer, how many times does the printer appear in your printer list?
1. Windows 10 Pro
2. I have only one Canon MF230 Series UFRII LT in my printer list.
Took a little break I see.  We're happy to see you back now.
Are you still using the printer with Windows 10 and connecting via USB?
