Direct Print Plus issues with custom ICC profiles
root
Hi, I recently switched from Direct Print and Share (2.7.0) to Direct Print Plus (1.5.1). I have a custom paper on several machines that have an ICC integrated (by Media Configuration Tool).
- Printing with Direct Print and Share with custom paper+ICC profile works perfectly fine. Colors are correct and also rendering intent is noticeable set as relative colometric.
- Direct Print Plus does ignore ICC profile from the custom paper or has wrong rendering settings. The colors are totally off.
I would like to use the (newer) Direct Print Plus due to better features and newer pdf engine. But without any possibility to adjust ICC or color rendering intent the tool is just useless. Anyone running this successfully with custom ICC?
0 REPLIES 0
