06-03-2023 02:12 PM
I just bought the imageClass MF653Cdw. The only two people who use this is myself and my wife in our home. I thought I sent it up fine (I had to manually input the IP address for the scanner). Today when I go to print the IPV IP address is different (and yes I get that warning). If I reconnect to wireless then it prints fine. I turned it off and turned it back on and same thing happened. What did I do wrong? What do I need to fix? (oh and I did not set it up where I needed a PIN to print or anything like that) Thank you
06-06-2023 02:50 PM
No worries. The SB6141 is a cable modem, It does not do any routing.
The RBR50 modem/router & RBS50 Satellites was Netgear's first generation mesh system.
You can grab the user guide here:
Orbi WiFi System (netgear.com)
Here is the manual for your Canon printer:
In case you have tried and failed or changed the setting on your printer, please use this reference to return the printers IP address to "Automatically Acquire" (DHCP).
<Auto Acquire>
Select to automatically assign an IP address via DHCP protocol. When <On> is displayed, automatic addressing is enabled.
What this does > It allows the printer to accept IP address assignment from the Orbi System. This includes an IP address, subnet mask and gateway.
Now perform the wireless set up process on the printer again. This will force it to query the router. It should in turn associate itself and get an IP address. One in the 192.168.0.x range.
Once complete, use the check settings command and confirm IP assignment
It will be something like
IP: 192.168.0.x The range of assignable address in the DHCP pool will be 192.168.0.2 ~ 192.168.0.254
Subnet mask: 255.255.255.0
Gateway: 192.168.0.1 (which just so happens to be the LAN IP of the Orbi router)
Now move to the router
Use a web browser > You should be able to log into the Orbi's admin portal at 192.168.0.1 or orbilogin.com
Now review page 73 of the Orbi user guide. This describes how to assign or reserve an IP address for a device on the LAN (local area network. In this case, the printer.
Log into the Orbi
Select the "Advanced Tab, now look in the navigation pane (left-hand side of the page)
Setup > LAN Set Up (unfortunately the new manuals don't have pictures, they used to. Here's some of my own that will help you 😉
To assign or reserve an IP, you need to specify the IP address the router has assigned to the printer, and enter its MAC address (unique identifier)
Note, if the printer is connected to your router and has been assigned an address its IP and MAC address will both appear in the list of connected devices. The only thing you are doing is telling the router I want this device (printer) to use and always get IP address x.
For simplicity, just use whatever the router has assigned. Once these settings are saved, you need to power off the printer. Wait a few minutes and turn it back on. This time when it connects to the wireless, the router will recognize it and assign it the IP you have specified previously. Note, the router will never assign this IP to another device unless you remove its assignment from the reservation list above.
Take a look and let us know how you make out.
06-11-2023 05:34 PM
Thanks. Work has been super busy, but will try this in the next day or two and let you know how it goes.
12-22-2024 01:06 PM
I have the exact same problem. My printer IP keeps reverting to 169.x after every few reboots. I have added a static IP but it keeps reverting to DHCP for some reason. Please let me know if you have found a solution!
12-22-2024 05:30 PM
The only solution I have found is to use my hot spot on my phone, make sure I am in the room with my printer then connect my computer and printer on the host spot. I haven't had any problems. Maybe there is an issue with my modem/router. I have a mesh system, but maybe the signal is to light (although a test says otherwise). But my modem and primary router is on the main level, and my printer is in the basement. hope this helps
