04-17-2024 05:11 PM
I recently purchased a Lide 300 scanner. I'm happy with it, but there's something that iritates me in the IJ Scan Utility. Even though I have made sure every "Save to a subfolder with current date" box is NOT checked in the settings, it still adds the date to the file name when it saves. It's a complete waste of time to enter the file name I want when it saves if I still have to go in and delete the date from the file name.
Is there a way to make it stop? What am I missing? Please help me!
04-17-2024 06:26 PM
I have not found a way to stop that. I think it is a protection step to avoid inadvertently overwriting a file if the same name is used.
01-07-2025 10:08 AM
Couldn't agree more. I scan about a dozen documents per week and I do not want/need the date of my scan included in the file name! (Note that I DO INCLUDE the appropriate date within the filename of nearly everything that I scan). And I do not want multiple folders within my "2024_personal" or "2025_personal" folder -- I just want to see all the files within the appropriate folder.
PLEASE, Canon, remove the requirement to append the scan date/time within the filename or create a new folder! Just write the file as specified to the intended folder. As a software developer I know that it is not terribly difficult to simply pop up a warning if the filename already exists in the intended folder so that the user can choose to "over write" the file or change the file name. If there's another version of the "Canon IJ Scan Utility Lite" that can be purchased that provides this capability I'd be willing to spend a reasonable amount of money to have that feature.
01-06-2026 11:56 AM
Just bought an LIDE 400, found MP Navigator is replaced with ij utility. I am finding same thing you are. Same as CheRay, scan several docs a week, I have own file naming system. ij is still adding the date after my file name, along with -_0001. For the next doc, I have to return to settings to change file name. Would also like to see a button to start the scan on the settings page.
05-14-2026 07:44 AM
2 years later still hoping this "feature" stops being a feature. Optional features are great, forced features are not.
09-01-2026 11:19 AM
Even worse, Canon does not understand the issue. In their Knowledge base there is an article titled "How Can I Prevent the Date from Appearing in a File Name After Scanning in Scan Utility?" but it only explains how to disable the file being added to a FOLDER with the current date. Come on Canon, take a minute to proofread your own articles! And then FIX this issue! Maybe the function is there to prevent overwriting files, but LET ME CHOOSE whether or not I need this. I have the scanner save files to the desktop, and then I move them from there to the folder I want. It's easier than choosing the destination folder each time. So I don't have an issue with files being overwritten. It shouldn't be so hard.
