How do I update my Wi-Fi password on PIXMA G7020
bcallahan
Installed a new router with the same name as the previous router but i changed the password to the new router.  the printer will not connect as it sees the wifi name and tries to use the old password.  I can't figure out how to update the password to the router on the printer.
1 REPLY 1
The easiest way to reconfigure your printer's network configuration, same name, new password, new name, new password, etc. is to run the setup utility again.  You need to put the printer into wireless connection setup mode first then run the software. Here's a tutorial.
https://support.usa.canon.com/kb/s/article/ART176129
