How do I cancel my old wifi connection and add a new one to my TS3522
Cricket73
We changed wifi networks and I am unable to figure out how to cancel the old and then add a new. Saw online that you can hold the STOP button to reset, but I get no flashing lights when  I do this
7 REPLIES 7
DerrickL
Whiz
Whiz
Updating Wi-Fi Connection for PIXMA TS4522
Preparation Steps
  1. Check Printer Status: Ensure your PIXMA TS4522 is powered on and ready.
  2. Gather Network Information: Have your Wi-Fi network name (SSID) and password ready.
Connecting to Wi-Fi
  1. Access Printer Settings:
    • On the printer, press the Home button.
    • Use the arrow keys to navigate to Settings and select it.
  2. Select Wireless LAN Setup:
    • Choose Wireless LAN Setup from the menu.
  3. Choose Connection Method:
    • Select Easy Setup or Standard Setup based on your preference.
  4. Connect to Network:
    • If using Easy Setup, the printer will search for available networks. Select your network and enter the password.
    • For Standard Setup, you may need to enter the SSID manually.
  5. Confirm Connection:
    • Once connected, the printer will display a confirmation message.
Troubleshooting Tips
  • No Network Found: Ensure your router is on and within range.
  • Incorrect Password: Double-check the Wi-Fi password for accuracy.
  • Reboot Devices: Restart your printer and router if issues persist.
Additional Resources
  • For detailed instructions, visit the Canon support website or refer to the printer's user manual.
this is for the TS45 model I have the TS35
and will this disconnect the old wifi connections
thanks
DerrickL
Whiz
Whiz
Yes, the printer can only connect to one wifi "connection" at a time.
is there different directions for the TS35? I don't have a TS45
DerrickL
Whiz
Whiz
TS3522 does not have  display so it does work different as listed here:
https://support.usa.canon.com/kb/s/article/ART179548
DerrickL
Whiz
Whiz
Yes because the printer does not have its own display it does have different directions or choices to connect to wifi as listed here:
