12-23-2024 10:44 AM
I have been frustrated by this issue also. I bought a new desktop machine and it immediately updated and installed Win11 24H2 on it. I then installed my Canon software for my printer MF750C and the MF Scan Utility would fail with the message mentioned many times in this thread.
I have installed all the latest updates and including the one Microsoft released 12/10/2024, KB5048667, but none of that made the scanner software work.
Now today I reinstalled just the drivers for the MF750C under the Imaging devices in Device Manager, and it started working, and has kept working as I think I have tested after rebooting at least 10 times today.
So bring up Device Manager, (right click on the Start Menu), expand Imaging devices, then right click your device, mine says Canon MF750C Series, (2 times). Now this part is important as I checked it twice and if you don't Disable the device first it doesn't seem to work right. So right click on the device and click Disable Device. My MF750C is listed twice here in Imaging devices, so be sure to Disable Device for both of them. Then right click on it again and select Browse my computer for drivers, then select Let me pick from a list of available drivers on my computer. Your printer/scanner should be in the list, make sure it is selected, then click Next.
Mine then came back and said Windows has successfully updated your drivers. Make sure you do this for BOTH of the devices listed there, at least if it lists two of them. Windows does say it updated the device driver. I'm not sure what it did for sure but it did something.
It doesn't say you have to, but I then rebooted my machine before I tried the software, but then the MF Scan Utility works! It has kept working for 2 days now, and after many reboots!
I don't know if this will work for everyone but so far it has worked for me. I have no ideas what made it work today. Microsoft and Canon, (and apparently HP and Brother), need to talk and get this resolved for people!
Merry Christmas!
02-09-2025 03:47 PM
Thank you! This fix worked for me with an ImageCLASS MF455dw. The printing via Wi-Fi had been troublesome after the Windows 11 24H2 update. I previously got the printing to work but the scanner stopped working again. I hope it stays fixed after this repair.
02-10-2025 01:24 PM
I tried this method, disabled the printer from device manager and then browsed my computer for drivers, and pointed it to search the drive where I downloaded the drivers from canon to. But then it told me I already have the most updated drivers installed. Should I install the drivers before trying all these?
02-10-2025 01:36 PM
I think it is important to reboot your computer, and then immediately go to device manager and disable the device, then try update the drivers. Do not try to print or scan after you reboot the computer. I don't know if this will work but I hope it does for you. I just wish Canon would acknowledge this issue and actually put out software to fix the driver issue. Good luck.
02-10-2025 01:52 PM
I think you have to do this sequence:
1. Open Control Panel
2. Open Device Manager
3. Open Imaging Devices
4. Open 1st Canon MF720C series
5. Select Driver tab
6. Select Disable Device
7. Repeat 4, 5, and 6 for second Canon MF720C series
8. Open 1st disabled Canon 720C series
9. Select Driver tab
10. Select Update Driver
11. Select Browse my computers for drivers
12. Select "Let me pick from a list of available drivers on my computer"
13. Select Microsoft eSCL Class Driver
14. Repeat steps 8 through 13 steps for second Canon MF720C
15. Restart PC
I think your mileage with vary on how well this works. As I said in my post, this worked partially for me (feeder scan on both sides was not available), I only got this to fully work by reinstalling the latest Canon drivers and then scanning both sides with the feeder starting working.
02-12-2025 04:40 AM
This solution worked for my MF753C. Thank you so much!!
02-12-2025 05:29 AM
Thanks. Probably because I already installed the most updated driver from Canon, when selected "Browse my computers for drivers" it refused to install saying "you have already installed the most updated drivers"
02-12-2025 03:00 PM
Windows will allow you to change or update a driver even if there is one that Windows says is the best one. You need to follow the steps very carefully. Don't let Windows select the driver.
02-13-2025 03:42 AM
This was the perfect solution to solve my Canon MF752Cdw scanner connection problem!
Thank you very much Dale1973!
02-13-2025 04:12 PM
Hello.
So I encountered this error today with an imageCLASS MF656CDW multi function unit. After some crazy stumbling around I found this combination to work on a Windows 11 24H2 PC with all current windows updates:
1. Install the Master Driver utility package (mastersetupv110) from the canon website
2. After this is installed, run the scanner utility package if you want to scan from your machine (winmfscanutilityv12102). If not skip this step.
3. Open device manager -> imaging devices -> canonMFmodel. Right-click and uninstall (but do not remove the driver package).
4. Download and run the [Windows 64bit] MF656Cdw/ MF654Cdw/ MF653Cdw/ MF652Cw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear) installer (MF650CMFDriverV720W64) package from the canon website
5. Follow all prompts and install all components that you plan on using (i unchecked faxing and the ability to install the service).
6. Once this finishes, go back to device manager -> imaging devices -> CanonMF model
7. Right-click and "Update Driver" -> Browse my computer for drivers -> Let me pick from a list of available drivers on my computer
8. For the 656CDW, you will see 2 drivers. One with a 2023 date and one with a 2021 date. Select the 2021 driver and click next to install/use it.
Once this is done, scanning was working again. Whether its directly from the printer or using the app or hard wired or setup wirelessly. Scanning was working great again. Oddly enough it looks like the last driver update was yesterday, but this driver doesn't work. Hopefully this helps someone save several hours, as it took me a while to get this to work 😞
02-15-2025 06:22 PM
Did not work with a MF216N on multiple computers...
Paul
