05-19-2016 06:51 PM
OS: Windows 10
Wireless internet
Canon PIXMA MG3620
I only purchased it as a scanner, and do not have it set up to print. It's been working for a few months, but sometimes it stops connecting to the wireless for no reason. Usually rebooting my PC, or the scanner will fix this.
This time it won't and I don't know what to do.
I've rebooted my computer and tried multiple times to pair my scanner with the wireless, but it doesn't seem to be properly connecting to my PC.
I get the error "Cannot communicate with scanner for these reasons:
-scanner is turned off.
-If using LAN connection, it is disconnected from LAN
(etc, etc)
Code:5,157,69
On the top of the scanner the Power button is lit (green), the wifi button is lit (blue) and the 8.5"x11" plain paper button is lit (green).
What do I need to do to get the scanner and computer connected again?
09-01-2020 08:39 PM
Hey 2020er! I am getting severely frustrated because no matter how long I hold the wifi button, none of the other buttons blink! Any advice would be amazing!
10-17-2020 12:35 AM
Hi Stacy,
Not sure if you would see this reply as your post was old. But I'd like to you thank you because my printer is now connected with the network after I followed your notes. I've spent hours yesterday, invain. The key word is "Immediately". Not sure how you figured that out, but you're great! Thank you!
BenD
10-24-2020 06:20 PM
11-01-2020 07:35 PM
11-01-2020 07:39 PM
Did you ever receive a response to your question? Mine is the same, I'm just wondering.
Thanks!
11-01-2020 08:01 PM
Hi Senebo,
No I have not received any response, I didn't expect any. The instructions provided are correct, it's just that you'll need to do it fast enough. Look for the post Stacy made on page 2 of this thread.
11-04-2020 09:50 PM - edited 11-04-2020 09:51 PM
I had the same trouble, tried several solutions: reset, restart router, connect to printer manually, using app in iphone, etc. The answer on page one, regarding a installation of a pc app works. https://ugp01.c-ij.com/ij/webmanual/WebPortal/PTL/ptl-setup.html?lng=en&type=setup&area=ca&mdl=MG362...
( although i have to work around it. it could not found the printer initially...
12-09-2020 09:39 AM
12-09-2020 03:45 PM
Hi M_Salas671,
Go to page 2 of this thread and check the notes posted by Stacy on 07-23-2017 12:32 AM.
02-17-2021 12:45 PM
