02-14-2022 01:43 PM
What setting will stop that?
02-14-2022 01:53 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know what model Canon equipment you are using. Any other details you'd like to give will only help the Community better understand your issue. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
02-14-2022 01:54 PM
I'm using the CanoScan 9000F Mark II.
02-21-2022 02:40 PM
Open the IJ Scan Utility and go to Settings. Once there, select the Default settings for each tab on the left and click OK.
If the issue persists, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
02-28-2022 01:37 PM
I set the defaults for each. It still saves two copies. No fix.
01-30-2024 08:49 AM
I have the same problem. At first, everything was fine, and then suddenly it started making two copies of each scan.
02-01-2024 02:14 PM
You can try removing and reinstalling the scanner driver but if that does not resolve the issue, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
