03-29-2026
07:54 PM
08:54 AM
James_C
I have had my printer (MX922, wireless) for years and it worked with multiple laptops. I just got a new laptop (Dell XPS, windows) and the install says complete but also says that it did not install. No other info was noted. I deactivated my anti-virus software thinking that might have been the issue. I also restarted both the laptop and the printer multiple times.
03-30-2026 01:01 PM
Does the new laptop have an Intel/AMD processor, or is it an ARM/Snapdragon? If the latter, you are stuck. No ARM driver available.
03-30-2026 01:09 PM
Thanks. That's what I thought. Can you recommend a compatible printer or whete to go to get a list? Anything I've found online so far conflicts with something else. It's not very clear.
03-30-2026 02:19 PM
It is a very common point of confusion when moving to a new Windows 11 ARM-based computer, but the good news is that your PIXMA MX922 is compatible! You just have to skip the traditional driver downloads and use the built-in Windows setup instead.
Because ARM processors handle software differently, the "Full Driver" package on the website won't run, but Windows 11 has a "Class Driver" already inside it that works with your printer. Here is the setup guide:
Simply plug the USB cable from your MX922 into your computer. Windows 11 should detect the hardware and automatically configure the printer for you.
If the printer isn't found automatically, use the Internet Printing Protocol (IPP) method:
03-30-2026 04:54 PM - edited 03-30-2026 04:57 PM
That clears things up a bit, just going by the support page for the MX922 or AI search does not mention ARM processors. This page does however along with all the other Canon printers that are compatible with ARM processors
03-30-2026 05:39 PM
This isn't "good news"! It's a cop-out. Windows' built-in driver does not provide all the functionality you get with a Canon driver on an Intel computer.
Is Canon really incapable of having ARM drivers written?
03-30-2026 08:55 PM
Does not work
03-30-2026 08:58 PM
I saw that page. Still not very clear because MX922 is on the page as compatible and we already know it’s not. The instruction for the windows driver install doesn’t work either. What a cluster!
03-30-2026 08:59 PM
Unbelievable, isn’t it????!!!!
