08-18-2015 04:47 PM
I cannot scan since downloading Windows 10. It says: You don't have the required privileges to access the specified folder Code 9,244,3
08-22-2015 06:47 AM
03-27-2020 02:45 PM
05-05-2020 04:28 PM
I tried all the solutions previously mentionned in this post and none works. Install with Admin privilege, turn off controlled Folder entirely, Add an application the access rights on the folders, change folder... And always the same message. Any Fix ? Any new idea ?
08-04-2020 03:19 AM
Hello,
I fixed that problem by changing user rights on profile folder.
I use a french Windows so I'm not sure about english terms.
Canon scan tool couldn't access to "documents" folder so it couldn't create scanned files.
I just added my own account in the security list and gaved it full access.
For security reasons, I just modified "documents" folder (instead of profile folder) that is the default folder used by my scan tool.
So right click on "documents" folder => Properties => Security => Modify => Add => Advanced => Search => Double Click on your own account => Ok => check Full access => Ok
