imageCLASS MF663Cdw Driver is "not supported by the computer"
seefour
Trying to install a new printer and I get this message when I open the driver.I picked the master driver set for windows 11.
I'm running windows 11 home.
I've tried:
-restarting the printer and my computer
-Installing with the windows tool without drives
-Running drivers in "compatibility" mode
-Downloading the individual driver and just using that
Nothing works.
This should not be this hard for a brand new printer.
4 REPLIES 4
Greetings ,
Is your computer based on a Snapdragon / ARM processor?
As a matter of fact it is. Seen this before?
Yes, we have. The Canon installers are supported under Intel and AMD based chipsets.  They will not install on ARM based systems.
Instead, you are relegated to native driver support provided by Microsoft.  I wish I had better news.
My suggestion would be to register the printer in your MyCanon account contact support for options.
MyCanon
https://myprofile.americas.canon.com/us/signin
 Support
1-800-652-2666
DerrickL
From Microsoft Windows:
Notes: We're aware of some ARM PCs (for example Copilot+ PCs) not being able to add/install a printer using the included installer or by downloading the installer from the manufacturer's website.
  • To fix this issue, go to Settings > Bluetooth & devices > Printers & scanners and select on "Add device" instead to add the printer manually, unless the manufacturer has specific guidance for Windows on ARM PCs.
  • To find out if you have an ARM device, go to Settings > System > About, and look for "System type" property under "Device specifications". ARM devices have "ARM based processor" under system type.
