01-22-2013 02:17 PM
Hello,
I am suddenly having problems with my S100. It will not take the picture when I press the shutter release. In case I had accidentally changed something, I did a Reset to Defaults. Then it worked, briefly, before returning to not working. It also would not let me change My Colors. Everything else seems to be working fine. Any ideas?
04-28-2015 04:16 PM
04-28-2015 04:22 PM
same as what that S2 person said his was...now the mystery lies in what part Canon sent out for a replacement.
Whats the odds of you have the receipt for that part and the part number being on it ?
04-28-2015 04:31 PM
I found the package in which my repair part arrived. There is an outer and an inner package, and both show the part number as CM1-7226-000. The outer package also says "Pick Location: AB0501K008." I guess that's where the good parts are kept. Of course just because a number is on the package does not guarantee that number is on the part. Since Wallygaw had the same experience as you, maybe you can get his attention and see what part he received.
05-02-2015 01:08 PM
05-02-2015 05:08 PM
Here is where things stand: Some have had success spraying in a contact cleaner called "Deoxit" available on Amazon. For most this fix was temporary. For some it seems to work well for a very long time. For me, after taking of the front cover and spraying deoxit on the shutter button, the camera worked fine for a couple of weeks and then it didn't. If you try that, protect the microphones from the spray and use sparingly. Since your shutter sort of works this may do it for you. See posts 186, 241 and 248. See posts 252 and 288 for excellent photos of the part that gets replaced. the shutter is that white button.
I (and at least one other member) had success ordering the part and replacing it myself. See post 354. At least two members replaced the part and then the camera would not turn on. The process of removing and replacing the part does not require very special tools or skills, but the more patient you are and the better you are at working with tiny parts, the more likely you will have success. I spent a couple of hours on it, working carefully and slowly. Make notes where each screw goes. Be sure that the representative who you order the part from knows what camera you have. In the photos you will see that the part has a number ending in 020, even though we ordered with a number ending in ooo. One member got a part ending in 030, and had an unsuccessful repair experience. We don't know if the part was the problem. the trickiest part is inserting into the main connector. You can't push hard because the circuit is flexible. You can't grip it with pliers because the circuit is extremely delicate. It's a matter of aligning and wiggling. Good luck. If you read the posts from about page 28 on, you will learn pretty much all that is known. Most earlier posts are basically rants. Best of luck.
05-02-2015 05:53 PM
05-10-2015 01:34 PM
I posted a few weeks ago that my DeOxit fixed S100 was still working fine – since then, it’s started acting up again. I guess I should have kept my mouth shut. I’ve always used Canon SLR’s, back from the A1, and EOS 1N to the 5d Mk3 I bought recently, and they’ve all been great cameras, never had any issues. Previously for compact cameras, I had always purchased Sony, and aside from some minor issues in image quality (red oversaturation, etc.), that were easily corrected in post, I really liked them. When I needed to upgrade, I decided to try the S100 since I’d always liked the Canon SLRs. That was a mistake. I’m not going to bother fixing my S100 – I’m going back to Sony for my compact cameras from now on.
05-10-2015 02:11 PM
I will give you $35. for it
05-10-2015 02:14 PM
05-10-2015 02:29 PM
