01-22-2013 02:17 PM
Hello,
I am suddenly having problems with my S100. It will not take the picture when I press the shutter release. In case I had accidentally changed something, I did a Reset to Defaults. Then it worked, briefly, before returning to not working. It also would not let me change My Colors. Everything else seems to be working fine. Any ideas?
12-02-2014 05:11 PM
Just an update on the DeoxIT fix (Post #186). The camera has been working fine since I used the DeoxIT on the shutter switch. Have taken around 200 photos since the fix without a single glitch.
It’s possible that you might be able to use the Deoxit directly on the shutter button itself instead of disassembling the camera (as John had suggested in an earlier post). I didn’t look at the penetration that the shutter button makes through the case top to see if it has any kind of seal, so I can’t say for sure if that would work or not, but if you have nothing else to lose, and don’t want to disassemble the camera, it’s worth a try. I’d get the Deoxit in the bottle with the needle applicator (you can find it on Amazon or any number of places). Take the battery out of the camera (always a good precaution when working on anything), push the shutter button down fully and put a few drops in the crack between the silver shutter button and the black ring that surrounds it. Hold the button down for several seconds, then operate the button a bunch of times to distribute the DeoxIT. Put the battery back in and test.
A few warnings:
12-02-2014 06:04 PM
Thanks for the update !
I doubt Canon is going to act on this at this point they are all hiding...it's a shame.
I would definitely try using the DeOxit without taking the camera apart first and yes DONT USE THE CHEAP STUFF !
DeOxit is the only product I am confident with, like you, for an application into a camera.
I'm happy to hear your camera is still working for you !
I would be willing to look at a few of these cameras for free just to satisfy or at least try to satisfy my own curiosity as to whether there is more than one chronic fault in these.
Seems I and you are more curious than Canon as far as getting to the bottom of this situation
12-05-2014 06:46 PM
It's definitely a shutter button issue. When the problem exists on my camera, I am able to get the shutter to trigger immediately by putting the entire surface of my finger over the shutter button and the zoom ring and then rocking the whole shutter/zoom assembly while pushing down to take a photo. Every time. That said, it isn't consistent on which way I have to rock the assembly. Sometimes it is forward, sometimes side-to-side, etc...
I like the Deoxit solution if it works, but I am not entirely sure the liquid can get anywhere of value from the outside (unsure if the button is sealed from the outside world). Looks like a dissassembly may be in my future.
12-05-2014 06:54 PM
well the good thing with the DeOxit is it wont harm anything and may help without taking the camera apart.
You've narrowed it down to the switch or the internal mounting of the switch.
Have you tried the other solution yet...blowing air into the ports on the same side as the shutter switch ?
12-05-2014 07:11 PM
@John_ wrote:Have you tried the other solution yet...blowing air into the ports on the same side as the shutter switch ?
No, and am not planning on it. At least, not with my mouth. Perhaps with compressed air at some point, but I'd rather get at the switch internally before I go down a route that, although seemingly successful in many cases, seems a bit coincidental as to fixing the issue.
12-05-2014 08:05 PM
yes it could be coincidental indeed. An air compressor set real low will also introduce less if any moisture.
There is only one way to get to the bottom of a solution and that is repeatability or measruement of continuity through that switch.
12-06-2014 12:38 AM
Just saw Canon is selling refurbished S100's now for $109.99....gee I wonder why? lol
12-06-2014 01:41 PM
Just an update.
I did take my camera apart and it was inspected by a friend who is familiar with electronics (he has made circuit boards for several devices). His comment was the solder around the shutter button looks fine. I did squirt it with DeoxIT and we put it back together. No problem ever since but we have only taken about 100 photos. I will update after our trip at Christmas as we will be taking a lot of photos with it... fingers crossed.
A piece of advice while taking it apart film yourself as you do it in case you have any questions on which screw goes where.
12-06-2014 02:00 PM
@John_ wrote:Just saw Canon is selling refurbished S100's now for $109.99....gee I wonder why? lol
The black S110's are $179 at various retailers too.
12-06-2014 03:21 PM
I agree, some of the screws in those cameras are only 0.5 mm different in length or 0.25 mm different in width or thread size...way to easy to get them mixed up.
I looked around the auction site and Canon actually has a better price at $109.99 than what I saw there for a used, non OEM refurbished camera from some person who said its tested and works.
I was looking for one that specifically stated it has a shutter button problem.
msostrowski...when you took it apart did you notice how the circuit board that holds the switch is mounted in there?
