08-11-2014 03:53 PM
i have an oldish powershot a560
i am tired of it claiming batteries are dead when they aren;t
i was thinking
it takes 2 AA batteries
i have been using eneloop rechargeables
what if i replace them both with one 14500 lithium cell?
will fill one cell holder with aluminum foil so it conducts
the voltage will be 3.7V instead of the max that 2 carbon-zinc cells could do, which is 3.30..
is the camera going to work, not work, complain, blow up, burn up, lose some functions, be damaged permanently?
wle
08-12-2014 01:18 PM
08-12-2014 01:44 PM
Hi Wlexxx!
Welcome to the Canon Forums! The Forums aren't intended for immediate assistance. If your question is of an urgent nature, please feel free to CONTACT US either by phone during business hours or email 24 hours a day!
08-12-2014 01:49 PM
08-12-2014 01:50 PM
08-12-2014 08:52 PM - edited 08-12-2014 09:01 PM
that 0.4 volt difference just might be enough to short out a back biased diode or even a forward biased diode would have a larger voltage drop across it than its rating. Also I assume those 14500 batteries have a higher MAH ( I didnt look that up) opposed to 2 AA's ? Think of it as a garden hose ( the circuits) rated at X amount of pressure (AA batt voltage). Now you increase the pressure on that hose (14500 batt voltage) that hose (the circuits) could fry. Maybe fry slowly it depends on the tolerances of the circuit lans and the components. The voltage can be compared to the pressure and the milliamps to volume of water.
My advice find an exact match voltage with a higher MAH rating or its a gamble.
If your trying to start at a higher voltage so it takes longer to reach the threshold voltage where that camera senses the batteries are dead you are likely to damage something.
08-13-2014 09:57 AM
Don't use the lithium cell. One of my co workers fried an A590 doing just that. Just make sure your batteries have an MAH rating of 2500 or more for longer life. MAH is milli amp hour, and like a car battery gives you an idea of how long the battery will last compared to other batteries. Keep the display time to a minimum, and even turn off the photo review to save battery life. Zooming and a lot of autofocus will drain the batteries quickly, so keep those things in mind when using the camera. And when you do recharge the batteries, make sure the batteries are as drained as possible and charge them fully. Even if you have to use the batteries in another electronice device to make sure they're "dead", it is important to fully deplete rechargable batteries to prevent them from getting a "memory" and not fully recharging. And only recharge the batteries when you actually intend to use them to get the longest life out of them.
Steve M.
08-13-2014 10:02 AM
08-13-2014 11:15 AM
Used only one cell. I am fairly sure it was 3.7v. Since this took place over a year ago I don't remember all the particulars except that he wound up buying a new camera.
Steve M.
08-13-2014 11:21 AM
wow
thanks
i won;t try then
also there is another reason not to try
2 nimh cells have about 4000 mah of energy
1 lithium 14500 cell has about 700 mah
point being, it still might not last as long as 2 nimh anyway
especially if you just used one cell
wle
