08-06-2016 09:34 PM
Several filters came with my sx500 the only one i put on was the UV and only because I wanted to protect the orginal lens. I am now wondering if since I had to use an adaptor to connect the UV filter that it may not be a good thing. Any comments?
08-08-2016 11:17 PM
Hi Nan156,
Thank you for your reply.
Canon does not offer a filter adapter for the PowerShot SX500 IS.
If you do have the PowerShot SX500 IS, I recommend double-checking with your dealer to ensure that the filter adapter is compatible with this camera model. If they can provide a manufacturer for the filter, I recommend double-checking with them for assistance in mounting the filter and adapter.
08-07-2016 03:08 AM - edited 08-07-2016 03:08 AM
A bad thing 'cos of the adaptor ring? Or the UV filter or both? Which one of the 3 options?
08-08-2016 04:54 PM
Hi Nan156,
Thank you for posting.
The lens on your camera was not designed to accept a filter and Canon does not recommend the use of third-party accessories with its cameras.
08-08-2016 09:21 PM
The adapter and the UV filter came with the camera
08-08-2016 10:07 PM
Hi Nan156,
Thank you for your feedback.
What are what brand & model adapter and filter were included with your product?
08-08-2016 10:45 PM
I do not know what make the adapter is but the UV is a Vivitar series 1 52 mm
08-08-2016 11:17 PM
Hi Nan156,
