08-07-2016 06:42 PM
mY 10 YEAR OLD POWER SHOT SX150IS WILL NOT NOT DOWNLOAD PICTURE FOR FIRST TIME.
08-08-2016 08:14 AM
Hi, taper21!
So that the Community can help you better, we will need to know exactly which operating system is running on your computer (Windows or Mac OS X, and which version thereof), and whether you're trying to download photos via the USB cable or a memory card reader. That, and any other details you'd like to give will help the Community better understand your issue!
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/ContactCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
08-08-2016 09:50 AM
Did you upgrade your operating system?
You might need to get a card reader.
08-10-2016 05:12 PM
befor trouble with downoading by accident clicked twice on off and on and got message on screen that computer must elliminate some things to fix trouble.
short time later that operation finished now download trouble.
What if I go to SYSTEM RESTORE AND PRECEDE OWNLOADING PROBLEM ?
08-20-2016 02:02 AM
I went to system restore and no luck.
Maybe never went back far enough.
Am always afraid of losing soething importand with that procedure but with this to fix I might as well go"way back" in "before" and see if that is the cure.
taper21
08-22-2016 03:13 PM
I went to 10th of month which was before trouble but restore outcome was-.
Could not do backup notice followed by.
Oxc0000056.
Whatever that means but, no luck at Restore.
I can have picture showing on camera screen and when turning on camera everything turns off.
Something in computer rejects the download.
Thanks,
taper21
08-25-2016 02:57 PM
I turned on computer today and flag tells me it will not turn on that Windows will fix trouble in computer which took about 20 minutes, when it shut down and started up.
So, I chcked an array of things in computer {pictures, ect.} and all "came up" so connected camers with cable to computer and same thing happened. It shut off camer as to downloading
Another thing.
After 15 minutes, or so, message in camera screen warns to Charge Batteries. I take them out and they show full charge in testing.
Thanks,
Taper21
08-31-2016 02:52 PM
With this camera, operation is getting worse.
Put in charged batterys printer screen says as soon as turned on .
And turning on camera, it starts up and shuts off .with the charged up batterys.
After about 12 years of fair amount of using it needs being sent in to get "All "things checked or set asside and buy another.
Thanks for all help
I will run it back again on system restore and see if that helps.
Canon is power shot sx150is. w 7.If I need to contack you again.
taper21
08-31-2016 03:07 PM
12 years is a long time for a battery. Get an OEM Canon battery as a replacement.
08-31-2016 03:27 PM
It takes two aa batterys which I have a dozen, or more, so changing is only a matter of minutes to put in charged up ones.
