03-10-2024 07:20 AM
Hello, I have been using my SX160 IS for past few months and there wasn't any problem. Today I took some pictures and found out that not even one of the previous photos that I had in the camera are not showing on the screen. When I did put my SD card in my computer, I could see all of them, but I also have found out that the camera made a new folder in which it put the new photos, even though it wasn't supposed to. Before all of this I renamed my previous folders with photos, maybe it has something to do with this problem.
If anyone could help me how I can make all of my pictures again seen on the camera screen, I'd be very grateful! Thank you:)
03-10-2024 12:40 PM
The filename and numbers depend on the folder structure the camera defines when a card is formatted by the camera. You cannot manually rename the folders on your SD card, and have the camera operate as intended. It won't know what to do. I suggest you copy all of the images off your card and store them safely in 2 locations. One will be a back up archive. Do not use your card as a back up for photos. In addition, having 2-3 cards is recommended. Swap them during shoots to ensure captured images are safe. You can lose everything at once using only 1 card.
