02-14-2016 09:31 PM
Camera wont read my SD card (just a plain SD no hc) says memory card error.When I try to format my memory card the format section is ghosted out!
02-14-2016 09:32 PM
I have an S2SI canon power shot, I put a new memory card in it and it wont read it. It says there is a memory card error. I checked to make sure the tab on the card was in the right position. I went to the tools in menu but the space for "format" is dark and I am unable to click on it? I am very frustrated with the whole thing. I hope someone can help! Thanks in advance!
02-14-2016 10:40 PM
Hi and yes try and narrow it down to either the card or the camera...try the card in a computer and see if you can access it there and format it.
03-08-2016 10:36 AM
Did you ever get this resolved? Have posted same problem and received two responses, both stating to use format on the menu, just as instruction book states. My function is ghosted out same as yours, and no one has responded. Would be nice if a factory tech person would review questions and give official, expert solutions.
03-08-2016 10:39 AM
Check your card. Make sure the card is not write protected. Check the switch on the card.
03-10-2016 06:15 PM
