02-13-2016 04:29 PM
I made sure that the card was in the in the "unlocked " position. And even tried a new one right out of the package. Same result
02-13-2016 07:04 PM
Maybe the switch is changing position as you insert it? When you removed the card was it still in the unlocked postion? If so there is a problem with the card reader slot. Also try it in a computer or other device if you can.
From what I understand the lock/unlock tab either activates a switch in the reader or not which tells the device, in thise case a camera, it can write to that card.
I've read some people say the lock/unlock tab does something internally to the card also.
I have a diagram of a card reader which shows it has tiny a write protect switch activated by the cards lock/unlock tab so I would suggest a strong light and magnifying glass and inspect, as best you can, the SD card slot. Look for any foreign objects etc in the slot something that might be interfering.
02-13-2016 07:07 PM
It sounds like the lock switch might be moving just enough to lock it when you insert the card into the G1x, and then moves it back when you remove the card. Visually inspect the card slot in the camera to make sure there is nothing interfering with the memory card.
Steve M.
