01-01-2021 07:06 PM
I am trying to hook up my iphone to an SX60 HS, and I am successful if I go through the process manually each time. I think I screwed up initially because I selected my home wifi and now it defaults to that intead of the Canon wifi that I manually select.
I tried to clear wifi settings but this didn't change it. So technically it is working, but when I press the phone symbol on the back, it takes me to the 'connect target device' page and won't cycle through to the settings that I am trying to save.
I would appreciate any help that someone can provide to start over on this. Thanks!
01-02-2021 10:33 AM
If your saved an incorrect profile, you can always delete it and start over, this time registering the correct destination (your mobile device).
Here is a Canon KB article for connecting the camera to an iPhone... you you need Android, let us know.
Canon Knowledge Base - Sending images from a camera to an iPhone (PowerShot SX60 HS / PowerShot G7X)
01-03-2021 01:22 PM
Thanks for your resonse. Unfortunately, unless I am glossing over the instructions that I need, this information mostly seems to pertain to syncing the phone/camera for the first time. I can get this to work by going through the process, but it doesn't memorize the connection.
When I go back to the app on my phone, it shows the wifi for my home. When I press the mobile phone symbol on the back of the camera, unlike the way I have seen demonstrated online where it syncs automatically, the camera is asking me to input the target device again.
I have tried to unistall wifi and followed the procedure to forget a device, nothing seems to change this process. So I can get it to work with the app, but I have to start from the beginning each time.
Thank you
