12-06-2018 02:40 PM
I purchased a used SX60 in very good condition but cannot get it to connect to anything. First, I reset everything to default. I set up a nickname for the camera. After downloading the app, upon pressing the phone button, I get two icons, one for a phone and one for a computer. I select the phone. A screen appears which says "searching for access points" and then almost immediately I get a "connection failed" notification. I've tried this multiple times, tried changing the wifi settings (which are very few). The MAC address shows nothing but a series of F's. Am I doing something wrong, or is the camera unable to generate a hot spot (which is what it appears).
12-06-2018 04:14 PM
Yes it is pretty simple to do and if you have the option to return/exchange it you should do that. The firmware may be corrupted
12-06-2018 03:55 PM - edited 12-06-2018 03:56 PM
And you have a memory card in the camera? I think you need that for any connections but not sure if that would prevent the camera from showing an SSID
12-06-2018 03:56 PM
Yes. Have a memory card, in the display mode. There is a brief flash of a screen that lasts less than a second before I get the error message.
12-06-2018 03:59 PM
That's not good and your right there are few WiFi settings and as far as I can tell the camera should just generate its own SSID without you doing anything else.
12-06-2018 04:10 PM
That's pretty much what I figured. I have a Sony a6000 so I've done this before. Just when it should go to the screen that shows the SSID, it flashes on a screen very briefly then goes to the error message. I also tried to connect it to my home wifi and after entering the password I got the same error message. May need to return this one. I thought I might be missing something obious but that's not evident after going through all the menus and documentation.
12-06-2018 04:14 PM
12-06-2018 04:18 PM
I assume there's no way to update the firmware?
12-06-2018 04:35 PM
I do not think so but I was wondering if you reset the WiFi settings to default thru the WiFi menu? The global reset to defaults does not reset the WiFi settings
12-06-2018 04:54 PM
Did it twice...had to rename the device but otherwise no change.
12-06-2018 05:02 PM
Well then the only other options you have is to see if someone else here comes up with something or contact Canon and see if they can help and at what cost or return the camera. Sorry I couldn't help you
