07-01-2024 08:18 PM
Hello,
I have an old PowerShot G7 from 2006 that takes very very dark images. Here is an image of a floor lamp with very reasonable lighting conditions taken at f/5.6 and a 1/2 sec shutter speed at ISO 80:
Here is the same subject and settings but at ISO 1600:
Does anyone know what the problem could be? Is there anything I can do to fix this?
Thanks in advance!
07-02-2024 03:09 PM - edited 07-02-2024 03:09 PM
Given, as you say, the camera is 18 years old, it may have succumbed to time. It's time to consider a replacement, and you may get some solace from the significant improvements in technology in the intervening time. Have a look at the Canon Refurbish camera page and see if you can find something there. These are new, or as good as but may have had the box opened, a damaged box, used for demonstration or show, but come with a discount and a warranty.
Canon Point and Shoot Cameras: PowerShot | Canon U.S.A, Inc.
07-01-2024 08:55 PM
Please start by resetting the camera's settings. Format the memory card. Now put the camera into [A+] auto mode. Go outside during the day and take a sequence of shots. What are the results.
07-01-2024 09:10 PM
Thanks for the quick reply!
In auto mode and broad daylight, I get completely black images like this one:
The flash also fires every time.
07-01-2024 10:19 PM
Did you reset the cameras settings as recommended? Reset, don't make any settings changes and test.
07-01-2024 11:27 PM
Hi and welcome to the forum:
If you have followed the advice by my colleague Rick, and have tried shooting in fully-automatic mode, yet still get the same results, I suspect that your camera has succumbed to the ravages of time. One final question. If you look at the rear LCD not in image review mode, what do you see - black or an actual image that looks reasonable?
07-02-2024 02:29 PM
Yep, camera settings were reset using the “Reset All…” option in the menus.
07-02-2024 02:34 PM
That’s unfortunate to hear.
Yes, both the ISO and shooting mode dials were set to AUTO for the test.
In shooting mode, the rear LCD also shows a completely black image. Sometimes when half-pressing the shutter, I’ll see a flicker of a very faint image of the scene (similar to the second picture in my original post) as autofocus does its thing.
