01-30-2025 03:53 PM - last edited on 01-30-2025 04:06 PM by Tiffany
My powershot SX 60 HS will not turn off. If I remove the battery, of course it turns off. When I re-insert the battery the camera turns on to the page where I set the date and time. I've removed the battery and memory card and held the power down for a minute. This didn't help. I got a tech-support person at Canon, and they did not have any suggestion other than send the camera in for repair. Any ideas would be appreciated.
01-30-2025 04:03 PM
Have you tried exercising the power button several times from several angles? You might see if it is stuck down.
01-30-2025 08:47 PM
Yes, the power button seems to be moving normally – it just doesn't have any effect.
01-31-2025 08:35 AM
Then, it needs to be fixed. I am not sure what you think we can do that the Canon person didn't.
02-03-2025 06:10 PM
Greetings perryy78,
If the camera powers on to where it is asking to set the date and time, then please to see if the camera functions after setting the date and time. In case the camera functions without issues, but the camera asks to set the date and time again after the camera is powered off and powered back on then there may be an issue with the internal date and time battery, or capacitor and we would suggest on sending the unit to our facility for repair. We would also provide the same recommendation in case the camera does not allow you to proceed with setting the date and time to use the camera to take pictures.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
