05-01-2013 07:10 PM - edited 05-05-2013 10:54 AM
UPDATED May 5:
I apologize to the forum for mixing two different problems. They are unrelated.
Problem #1: User error. I thought I was using a class 6 SD card but I was wrong. The yellow "!" indicates a pathologically slow card. Upgrading to a class 10 resolved this problem.
Problem #2: UNRESOLVED. Red battery indicator comes on prematurely. On a fresh charge, it'll turn red after recording for a couple of minutes. On a partially drained battery, it turns red immediately upon entering movie mode or pressing the record button. Turn the camera off and then right back on in "still" mode and it shows full charge and works fine ... until trying to shoot video. I have not precisely measured recording times but it'll record for at least 20 (maybe 30?) minutes while flashing red.
03-12-2015 12:27 PM
Canon apparently thinks it's fair. I too have crossed Canon off my list. I sent my camera in to be "fixed" some time ago and it came back with the same problem. Don't think they even took it out of the box. I use the tape method over the battery terminal. It works but inconvenient.
03-12-2015 04:53 PM
It's not just the SX700 series, it's the same with the S100 sticky shutter problem. A Panasonic or Sony would blow the socks of the SX700's regarding battery life when video recording.... and stills for that matter.
When I send a camera in I want to be getting my own back, not a refurbished one you don't know who's had. Until I hear different I too will stay away from Canon products.
The complaints could easily be halved if Canon offered a refund or a refund with cash adjustment against another model.
Reading between the lines tells me these faults are not solved at factory level, just what was Canon doing releasing them without proper testing, what was their quality control doing..... on vacation were they?
03-12-2015 05:09 PM
It's easy because they are a good company canon believe that they can do anything... As you can see they release a bad camera and still selling....
04-22-2015 05:07 PM
So if the serial number on the camera is not in the range given, or it has the mark as described , does that mean that the camera does work okay in video mode ?
I realy want to buy this camera as it has excellent reviews, and is now £99 in the UK. But ... I was hoping to use it instead of a video camera as well as stills.
04-22-2015 05:29 PM
Forget it! Check out another brand. Sony or other.
04-23-2015 12:46 PM
@ MrBenn
Whoooa, slow up a bit, here you are about to buy a camera for £99 when they were almost three times that brand new. You would do well to ask yourself a question or two here.
Why so cheap, is it a refurbised unit, what if it goes faulty..... one thing you won't be getting a brand spanking new unit, you can gurantee Canon will have had their sticky hands on it at a repair center.
Maybe they just want to get rid of them, if that was the case why haven't they all been sold, I smell a rat and it stinks, can anyone else smell it?
Davy
04-23-2015 12:50 PM
Agree. I have payed a camera that doesn't work properly... Canon don't assume the error... Don't buy Canon...
04-23-2015 01:58 PM
This camera is a lemon. You're paying £99 for a camera that may or may not work when you need it most. The serial number range is Canon's claim. No one here ever found a true cure, just janky workarounds that involve tape and jumper cables.
04-23-2015 03:16 PM
I love my two SLR Canons and I fixed my SX280 with the velcro. Works fine now but it is a lemon and takes great pictures. I hardly use the video because I have dedicated Sony's for that.
04-23-2015 03:21 PM
