10-25-2016 04:08 PM
How can I make the camera default to single image shooting mode or, better yet, disable continuous shooting mode altogether. I am spending too much time deleting the multiple images. I know how to select Single Shooting mode in the menu system but from time to time, probably becuase I press some function button without realizing it, I find it bac into Continuus mode.
10-27-2016 05:08 PM
Hi Pjafla,
Thank you for taking time to post.
When you press the UP arrow on the back of the camera, you'll see the "Drive" options there. You should currently see <
> highlighted. Use the left or right arrow to select <
>, then press the FUNC SET button.
10-27-2016 06:40 PM
Yes, I understand.
I have found what for me might be a solution. I have set Single Shooting along with other options I want in the P mode and then saved the settings to Custom. Now when I operate in Custom mode if I accidenatlly change something, such as getting back into Continuous shooting, a power off/on gets me back where I was.
Since there does not appear to be a way to simply permanently disable Continuous shooting, I think this will work for me.
10-25-2016 04:22 PM
What mode are you shooting in?
10-25-2016 05:19 PM
Program - which I prefer - or Auto, where I have less of a problem with this..
10-27-2016 05:08 PM
Hi Pjafla,
10-27-2016 06:40 PM
Yes, I understand.
