07-08-2015 05:34 PM
I am having trouble with my new PS G16. When trying to photograph a small item in macro mode, the camera focusses on the background instead. It occurs even when the item fills most of the focussing rectangle.
07-11-2015 08:10 PM
07-11-2015 08:18 PM
07-13-2015 09:25 PM
You might be too close to the item you are trying to photograph, but with a range of 0.4 inches (1 cm) to 1.6 feet (50 cm) I kind of doubt that. It sounds like the focus point is not on the item that you are shooting. Press the AF Frame selector button and move the box with the left/right/up/down arrows until you have the box over the item you want in focus, then take the shot.
Steve M.
07-22-2015 09:34 PM
I made a point to be sure that I am within range. Also, I set the camera to magnify the area of focus and to reduce the AF frame size, so I am sure that I am focussing on the right item.
Sometimes it focusses just right. As I try to get more photos of the same item, it suddenly losses focus and will not focus again on the item. After a while I give up. I think there is something wrong with the camera
02-13-2016 10:17 AM - edited 02-13-2016 10:18 AM
Are you hand holding the camera or using a tripod? Most macro shots lose focus because we move ever so slightly when we press the shutter button, causing the camera to use another focal point. The G16 has the capability to lock the focus so that when you are ready to shoot, the camera won't try to refocus. I would use that and a tripod with a 2 second delay and you should see better results.
Steve M.
02-13-2016 08:33 AM
02-13-2016 09:11 PM
10-18-2016 01:34 PM
I love my Powershot G16 but sometimes, in Auto or P mode, it just will not focus. It goes very out of focus and you can hear the motor going backwards and forwards. The only solution seems to be to turn it off and on again. Any thoughts anyone?
