08-27-2024
10:54 AM
11:26 AM
Hello,
I have an old Canon G15 Camera and the serial number has disappeared over years of use many years ago. I need the serial number ? How do I get it ?
08-30-2024 12:48 AM
Hi there,
The serial number information is embedded in the metadata of each image file, so if you are able to look at the properties or additional information of the file you will be able to locate the serial number of the camera. For a Windows computer you would do this by right-clicking the image file and choosing "Properties"
09-04-2024 08:48 PM
Unable to see this info in the pictures saved in the camera. Unable to download it to check on windows !
09-04-2024 09:13 PM
No software is required to download images saved to your camera. You can use a cable or card reader in windows or MAC OS.
"Unable to see this info in the pictures saved in the camera. Unable to download it to check on windows !"
If you'd like to get the serial number and its worn off the body, this is the only other method for getting the serial number.
09-04-2024 09:41 PM
Hi Mark,
If you had registered the warranty for the camera, you could go back there and check out the serial number.
Cheers!
