My Canon SX50HS
rileyBr
Can someone please tell me how I can change the aspect ration on my camera? I want to go from portrait to landscape.
Thank you
Philip Riley
2 REPLIES 2
kvbarkley
It should be in landscape when you hold the camera "normally", you switch to portrait by turning it on its side.
Tronhard
VIP
VIP
If you mean that you want to rotate an image taken in portrait mode, i.e. with the camera turned 90deg from it normal orientation, P182 of the manual.
Normally, when you take an image it should auto-rotate, but if you look on P183 you can see how to turn that feature on and off.
If you don't have a copy of the manual (you should!), go here to download a PDF copy. pssx50hs-cug-en.pdf (c-wss.com)
cheers, TREVOR
