03-12-2013 06:08 PM
Picked up this camera on Ebay because I read some good reviews, but for the life of me I can't get a resolution more than 180 dpi, whether I follow the directions in the manual for setting manually in the P mode for either size or quality. If I want to print something, it should be at least 300dpi. I want my images to have enough pixels for a nice print. Is there something I am not seeing? Does this camera even have the capability of doing that? Thanks for any input.
03-12-2013 09:12 PM
Unless you are going to print using Photoshop to do it IGNORE the DPI info. Turn your RULER on to see how big PHOTOSHOP says it will be at 180 DPI.I'd bet it will be much larger than you expect. Do not resample up or down from your original file, that's not necessary. Set your camera to shoot in large fine jpg & check the file size & pixel width & height to verify they match the camera speccs.
03-12-2013 07:24 PM
You are letting your software fool you. The camera shoots in PIXELS, not DPI. The software is telling you how big it will be ABLE to print the photo AT 180 dpi. You DO NOT have to print it at that size unless you want to & your printer can.
03-12-2013 08:51 PM
03-12-2013 09:12 PM
06-13-2013 12:21 AM
you want keep maximum quality while compressing ?generally I shall resize image and save it as .jpg and then print it.however image saving and printing guide found by Google may give you some useful info.
09-01-2013 10:41 PM
@nesca wrote:you want keep maximum quality while compressing ?generally I shall resize image and save it as .jpg and then print it.however image saving and printing guide found by Google may give you some useful info.
thanks for sharing, that's awesome but somewhat overpriced for me who will just use it only once, do you have some cheaper or even free versions, any suggestion will be appreciated!
09-04-2013 05:35 PM
