How to reduce the size ( pixelage ) of the picture
newsense52
Rising Star
SX710 HS, 20 MP, how to reduce from 7K to small K for posting and to share a photo in this site.
5 REPLIES 5
kvbarkley
What software do you use?
John_
I use Paint software for doing that you can reduce it by pixel size or percentage and it's a simple program nothing fancy or complicated
BurnUnit
Whiz
Whiz
If necessary, you can also downsize your images in-camera after shooting at full resolution. Check the manual below...
http://gdlp01.c-wss.com/gds/1/0300017421/01/pssx710hs-cu-en.pdf
...and fast-forward to page 97.
This was helpful and easy to resize than moving/using  other software.
Thanks good work.
I mighht have also mentioned to make sure you save your downsized images as copies. You probably don't want to overwrite the full size originals. Robot Sad
