10-16-2023 08:19 AM
Title, looking for a sharp quality image and I’m worried the g5x will be softer that the g7x. I’ve also heard that the viewfinder is gray on the g5x but not sure it’s essential. Which do you prefer for photos? Thanks!
10-16-2023 02:42 PM - edited 10-16-2023 03:19 PM
Hi and welcome to the forum:
Having shot with both, I would say the main difference between them are sensor size and focal length.
The G1XMkIII has the bigger sensor, which might be helpful if you are considering producing larger prints, for example, but it has the shorter focal range. It does have the advantage of some weather sealing.
The G5X sports a smaller sensor (which is still a good one) and a longer focal length, which will advantage you in being able to zoom into isolate or reach subjects. It will still produce good, clear images. Both are good cameras.
BTW, I would recommend using the electronic viewfinders over the rear LCD, you will find that you get much steadier results with less blur from camera movement.
I recommend you spend some time getting to know the camera and controls, and read the manual - take it with you when you travel or download a PDF from the Canon support site for the model you choose.
They are both good cameras, the rest is up to how you use them.
