03-21-2016 10:22 PM - edited 03-21-2016 10:23 PM
03-21-2016 11:58 PM
Thats not good and will most likely need service unless it's still under warranty in which case call Canon
If your handy you can probably find info on the web about how to take it apart and the part number of the circuit board underneaath the mechanical dial. But you'd have to take it apart to determine which it is the dail or the board.
There is another kind of reset you can try, fingers crossed, where you remove the battery and hold the on switch in the on position for at least 30-45 seconds...then replace the battery and try again
03-22-2016 12:19 AM
03-22-2016 01:32 AM
