12-09-2019 07:27 AM
12-09-2019 02:26 PM
Are you using a Canon battery or a third-party, non-OEM battery?
Are you using a full sized SD card or a micro SD with an adapter?
12-12-2019 06:49 PM
I am using a canon battery, and a full sized SD card no adapter
12-12-2019 07:13 PM
Ok, how old is your battery? The least expensive solution to try is a new battery. Even though yours might indicate a full charge it may have lost its capacity and goes flat instantly when you boot up your camera.
12-12-2019 07:45 PM
The battery is only two years old?
12-12-2019 07:53 PM
That battery is no spring chicken, 2 years is pretty good in camera battery years. All I can say is if I were you I would buy a new battery.
12-09-2019 04:56 PM
Check what BurnUnit said, try turning it on without the SD card but in any case use a full size SD card. Replace the battery with a new Canon made one
12-12-2019 09:13 PM
12-13-2019 08:21 AM
I kind of doubt it, but how about the battery and memory card door switch? Try putting a little extra thumb pressure on the closed door when you try powering it up.
12-13-2019 08:43 AM
