05-05-2024 10:39 PM
Hello,
A couple years ago my Canon Powershot S95 camera was dropped. Since then I've had issues with taking photos, but it has gotten progressively worse. I used to be able to wiggle the lens a little to get the camera to work, but now all of my photos are purple. I can still take photos, this photo attached to the post is from the SD card. The LCD screen also displays this purple haze, and seems to be functioning fine as I can still navigate menus. The lens also goes in and out just fine from what I can tell. My question is, what exactly is broken here? Is it the lens? or is it the sensor itself? I'm hopeful I might be able to fix it but I'm not sure if it would be worth attempting to open the camera or not. Thank you so much for your help!!s95 pic.jpg
05-21-2024 03:47 PM
okay, well I am happy to report that I did find a solution! I spent a long time internet searching and determined that it was likely the sensor that was the issue. I watched a video taking apart the camera and determined that while it was possible I could do it, I could also break the camera more, so I didn't consider myself quite talented enough to try. So I paid a camera repair person to put a sensor in from an old S95. It works again!! I'm quite pleased with the result as I spent $100 to repair the camera and now have my sentimental camera back in business. Here is a pic of my trusty S95 taken with my Canon G7X MkII.
s95
I hope this helps someone out there who's also having this kind of trouble. Thanks!
05-06-2024 03:00 AM
These things are incredibly complicated pieces of engineering. Opening it up thinking you can fix it is dreaming. You dropped it, it broke, say farewell and get another camera.
05-06-2024 03:47 AM - edited 05-06-2024 03:47 AM
To agree with my colleague - these are not things that one can work on without specific tools because of their precision. Your camera is quite old and no longer supported for service. Your best bet is to look to upgrade to a newer camera - maybe an insurance claim?
05-06-2024 10:17 AM
While unfortunate, my colleagues have provided the best advice. Canon has a loyalty program that helps people who are in your situation. Call a Canon Upgrade Program specialist and tell them your story. You get a small discount and shipping is free too. You can reach them weekdays and Saturdays at 1-866-443-8002.
05-21-2024 03:47 PM
s95
05-21-2024 05:03 PM
You are darned lucky to find someone who had a donor camera and was able to do the surgery.
Congratulations!
12-11-2024 03:50 PM
Can I ask who you had repair it? I have the same issue with mine after I gave it to my daughter. Someone dropped the camera and not the sensor is broken. None of my local camera repair places in Pittsburgh PA will even look at it.
12-12-2024 04:36 PM
I did it through ebay! the username is parts4camera, they have listings for a variety of cameras.
12-13-2024 07:54 AM
Thank you. I will look them up.
