05-12-2025 01:11 AM
I’m having Powershot V1 for a while now, just notice the Movie rec size menu is completely missing the 4k crop 59.94p option!! How is that possible!? Why is that so? Is there some wrong with the camera? I tried different shooting modes reset the camera, but still not a 4K crop 60p option!!
05-12-2025 01:48 AM
Thanks very much for the info, yes I set it to pal and back to ntsc to see if it will be back in the menu, but no help, the pal movie rec size is even more limited, not even having the FHD 59.94p , I do have that in the menu but Not in 4k crop ,
I will try other remedies you mentioned, thank you.
05-12-2025 02:04 AM
Problem solved!
Thanks again 😄
05-13-2025 04:39 AM - edited 05-13-2025 04:39 AM
I still can't get mine to work, so I'm assuming that the issue's with the write speed of the card?
My fastest SD card on hand goes only up to 170Mbps, but that should theoretically allow 50/60FPS 4K for "IPB (Light)" (approx. 120Mbps) even if it's too slow for "IPB (Standard)" (approx. 230Mbps).
05-15-2025 04:28 PM
I just watched a YT vid that explains that if you set Mode to SCN, you'll get the 4K/60 fps option.
05-30-2025 10:06 PM
Hi Sivand. Can you please share how you solved this? Thank you
