04-02-2022 06:52 PM
Recent Canon SD960 IS purchase. When using 16mb or 32mb cards, the camera indicates "card error". The format option is "greyed out". Tried several different cards, including Canon EOM. Any ideas? Thank you
04-02-2022 07:33 PM
Is it the right kind of card?
Also make sure the write protect tab is not set to protect. If it is not, the little sensor in the card compartment may be faulty.
04-02-2022 08:10 PM
Thank you for the response. I have four SD cards, PNY, Raw Steel, and SanDisk 16gb plus a SanDisk 32gb. Tried the protect tab in both positions.
04-03-2022 01:42 PM
Make sure they are full size SD cards, not the micro-SD cards that use plastic adapters.
