06-01-2015 06:27 PM - edited 06-01-2015 06:30 PM
Hello,
I ended up reaching 9999 photo captures on my G7X, afterwards, my photo file names restarted and reset to 0001. However, unforunately, none of those subsequent photos show up. I had geo-loccation tagging on my phone setup, and was hoping to tag the location of the photos.
I have tried renaming the files, changing them to a new SD card, nothing is working.
I would like to:
1) Get the files to show under the cameras preview mode
2) Send the GPS loccation information to the photos.
I would like to get this to work. In the mean time, I am using another SD card for the time being because I don't want to erase or mess with the files. If I take pictures with this new SD card, everything works fiine, the pictures show up in the cameras preview mode.
If anyone could help me out, that would be great.
06-01-2015 08:06 PM - edited 06-01-2015 08:12 PM
06-02-2015 04:45 PM
No, not all 9999 photos are on the SD card, it was just maybe 1000 or so.
When I try and use the Canon Camera Connect app to add GPS, it doesn't add any GPS data. When I try and view the images directly from the camera, it doesn't "see" any of the new images, even after renaming the CANONMSC to *_bak.
I use different SD cards every time I go out to new locations. With a continuous naming scheme, to see how many pictures I have taken. I do format the data on the SD cards.
My issue is only that I can't add GPS data to the images at this point.
06-02-2015 05:02 PM
You can also set the images to be stored in a Daily or Mothly folder
As far as your GSP problem you have the correct date, time and time zone set ?
During playback of your images can you see the GPS info there? You have to press the down arrow on the func/set wheel to toggle thru till you get to the display of full information like the GPS info.
06-02-2015 05:13 PM
I can show you a video of what I mean tomorrow (it is currently 23:30 where I am).
Because the problem itself is a bit confusing for me to descibe I suppose. It's a combination of problems.
