Can the SX540 be hooked up to ta laptop as a webcam?
NeedAnswers
Is it possible to hook the SX 540 HS to a laptop as a webcam? And if so, what cables are needed?
Thank you!
7 REPLIES 7
The software is still in beta release.  Your camera is not listed as supported, but you can try it if you wish.
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/eos-webcam-utility/
Cable:  Standard USB on the computer side.  Mini-USB type B on the camera side.
Thank you, I will give it go!!
Which camera is closest to the SX540? As a followup to the link you sent to try, I don't know which camera utility I should download...which is closest to my camera?
Thank you...
Ah, found my answer to my last question Smiley Happy
Catiocake
So does the canon Powershot sx540 HS work as A webcam
No
hello, could you  use your powershot sx540-hs as a webcam,
best regards
