11-17-2015 08:19 PM
Cannon IJ Network Scan Utility is in my " add/ remove programs", but date installed is the only thing filled; publisher, size, and version are blank. I can't access it, or do anything. Please help. Thanx
11-19-2015 03:32 PM
GOT IT!
go to cannon.com/cusa/home
support
drivers/downloads
enter model and choose from dropdown
forget what is in your face (recommended download), and look for the four boxes, side by side. First is downloads, NEXT IS SOFTWARE; CLICK.
go down to MP Navagator and get er done!
yours truly,
Stupid
11-17-2015 08:30 PM
Hi!
To ensure the most accurate information is provided, we will need to know the version of Windows in use.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks and have a great day!
11-17-2015 10:33 PM - edited 11-18-2015 02:09 PM
windows 10
1-reset mx340 to factory default settings.
2-Installed recommended drivers from Cannon site 11/18/15
Setup Results
Model :
Canon MX340 series
Network Setup of the Printer :
Completed
Name :
Canon MX340 series Printer (Copy 1)
Port Name :
CNBJNP_001E8F858E11
Network Setup of the Scanner :
Completed
Name :
Canon MX340 series(00.1E.8F.85.8E.11)
Network Setup of the Fax :
Completed
Name :
Canon MX340 series FAX (Copy 1)
Port Name :
CNBJNPFAX_001E8F858E11
Network Type :
Infrastructure
SSID :
SC........
11/18/15
Windows 10
"This PC>OS(C:)>program files(x86)>Cannon>Cannon IJ network scan utility"
CNMNSUT "Date modified" did not change from 8/23/10
Scan utility will not open.
11-19-2015 12:59 PM
Hello.
Hello, additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
11-19-2015 01:57 PM
"contact us" is an endless loop that shows new products. Are you a real person?
11-19-2015 02:05 PM
Hi rgfoote!
Yes, we are real people! You can reach our friendly, United States based technical support team by calling 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT). They will be able to help you with your PIXMA MX340.
Thanks!
11-19-2015 03:32 PM
GOT IT!
support
drivers/downloads
yours truly,
Stupid
