mf634cdw scanner utility not working
tth
I've downloaded the scanner utility but get an error message Code:9,230,0 A scanner driver supporting this software is not installed.  Install it and try again.
I've installed multiple times but still I get this message.  I'm on Windows 10 64 bit.
1 REPLY 1
Patrice
Whiz
Hi tth.
If the scanner is connected to the network, please confirm that it is selected in the MF Network Scan Utility by following the instructions below:
1. Click  in the system tray.
2. Select the check box for the machine, and click [OK].
If the scanner is selected, then it is recommended that you uninstall and reinstall the drivers while your antivirus software is temporarily disabled. To uninstall the drivers, please follow the steps below:
1. On your computer, open [Control Panel] > [Devices and Printers].
2. Right-click on the MF630 Series printer, and then select [Remove Device].
3. Return to [Control Panel], and then select [Programs] or [Programs and Features] > [Uninstall a Program].
4. Double-click on the MF630Series, and then follow the prompts to uninstall the files.
5. Restart the computer.
Once the computer restarts, please click the link below to download and reinstall the drivers:
MF632CMFDriverV5401W64usEN.exe
After the drivers have been reinstalled, scan a document, and then re-enable your antivirus software.
If you continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
