05-12-2020 01:18 PM
I happened to reach a printer settings page and saw the item 'apps permissions on/off'. Since I am always wary of undefined 'permissions' I set it to 'off'. Now I am experiencing problems that may have been caused by that change, such as some document displays not showing the range of print controls that the printer allows.
I would like to reset that 'apps permission' back on, but now I cannot find the page containing that control. The users manual does not seem to show it either.
Can someone help ?
05-12-2020 04:21 PM
Hi zayde.
The MF236n does not have an all-encompassing app control on the menu itself. Some of the settings require you to enter the PIN code for the System Management Settings.
More likely, the settings to which you're referring are the Airprint/Google Cloud Print/Web Services settings in the printer's Remote UI. If this has been disabled, it may be re-enabled through the System Management settings.
If this answered your question, please click the Accept as Solution button, so others might find the answer.
