imageCLASS MF8580Cdw Displaying Remaining Toner status in Windows 10/11
Rlindsey
Is there a way to display remaining toner status in Windows 10/11? The enclosed excerpts from Windows UFR II/UFRII LT/LIPSLX/CARPS2/PCL6 V4 Printer Driver document identifies that under the Support/Device tab this functionality "[Remaining Toner]: Displays the amount of remaining toner retrieved from the device." should exists.  The Support/Device tab did not show up when I installed the driver (last figure).
canon-Support.JPGcanon-Support.JPG1702068581742-319befef-1f58-47c4-90e5-f1282fc0e1f3_2.jpg1702068581742-319befef-1f58-47c4-90e5-f1282fc0e1f3_2.jpgcanon-driver_Installed.JPGcanon-driver_Installed.JPG
1 REPLY 1
Hector
Hello,
To check the toner level on your MF8580Cdw, you would need to use the operation panel on the printer. You can press the status monitor button and then select device status and press ok. In the device status window, you can check the toner levels.
