imageCLASS MF753Cdw will not come out of sleep
crapko
Another POS printer.     Why will it not come out of sleep,   50% of the time the print job status is "printed" and it is not,  send it again and later in the day i might have double or triple.
Also,  How to stop the incesenet toner status pop up.   for 2 months it reports from 100% , 50%,, 70% and back to 100% depending on the day.
CHris
6 REPLIES 6
Can you please confirm the model number of your product?  Canon does not make a M750.
I'm going to guess iSENSYS MF750?
What operating system (version and build) are you using the printer with?
Is the toner status notification displaying on the printer itself or computer?
Lastly, how is it connected and to what?
I'll make some recommendations once you confirm and provide the requested information.
Stephen
Moderator
Moderator
Hi there!
So that the Community can help you better, we will need to know more information:
• What exact model printer are you using (usually on the top or front of the unit)?
• Do you see any error messages?
• Which version of Windows or macOS are you using?
• How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks, and have a great day!
It is a MF753cdw,,,  connected WIFI,   using windows 7 and 10,,  acts the same..   This morning,,  did wake up 3 minutes after sending the print..   The toner status is on my PC screen.
Image class 753 CDW,
Chris,
Let's not start multiple threads.  I've answered your other post.
https://community.usa.canon.com/t5/Office-Printers/Image-Class-753CDW-SUCKS-at-everything-now/td-p/5...
Lets stick with it
Hector
Hello,
If the prints work half of the time and the printer is connected to the network via wifi, it will usually point to a network communications issue, or the printer has a weak connection to the router. In this situation, you can try manually setting an IP address for the printer. You can do that by logging into your router and setting a static address or you can manually set the IP address using the button panel on the printer
If manually setting the ip address does not resolve the issue, you can also try moving the printer closer to the router to see if the printer connection is more reliable. For assistance setting the ip address or to check the network connection to see what is going on, you can contact support over the phone at 1-800-652-2666. Our agents would be happy to assist.
