09-09-2022
05:22 PM
08:53 AM
Just installed a Canon MF746Cdw printer.
Trying to print a ONE page Word document.
If I print ONE copy, all is well.
When I print Multiple copies (let's say 3) of this one-page document, the following happens:
Paper starts to exit the printer, but reverses back into the machine as if for a two-sided document. It then prints my document on the flip side (verified). It does the same flip and print for the second copy. After a pause of a few seconds, the LAST copy prints normally - no flipping of the paper.
Aside from the fact that it should NOT be doing this, if effectively doubles the time it takes to print a set of multiple copies.
Anyone see this before? Any thoughts?
If I've put this in the wrong location, please advise and I'll repost it elsewhere.
thanks in advance!
09-10-2022 11:13 AM
Updates: Forgot to say I'm working from a MAC. Also, this does not occur if I send it from my iPhone.
09-21-2022 03:25 PM - edited 09-21-2022 03:28 PM
Hello Froderich,
You can try adjusting the setting for print side priority to speed priority from the menu on the printer.
<Menu> <Function Settings> <Common> <Paper Feed Settings> <Switch Paper Feed Method> Select the paper source Select <Speed Priority> or <Print Side Priority>
If you continue to have the same issue after changing the setting, we would need some additional information to assist further. If you could reply to this post with the information below, we can provide some suggestions or troubleshooting steps.
