01-15-2019
10:26 PM
10:11 AM
Hello,
I recently bought a Canon MF731cdw printer. I have set all the parameters as described in threads here or on Google such as Network settings smtp.gmail.com, the email address/password, port=857 etc. Turned the printer off for 30 sec- 1min or so as told in some threads. The process still gives an error #806 or # 801 or #753. Any ideas how on what may be happening? The gmail address is correct. Any other settings that I may be missing? Also, how to set up if the addresses are yahoo.com or hotmail.com
Thanks,
01-21-2019 02:18 PM
Hi reges.
The errors that you are receiving indicate that the server destination is not correct. You may want to confirm the SMTP port settings for Gmail. You can view more about the settings at the link below:
NOTE: This link will will take you to a page outside of Canon.
We will have to recommend contacting Yahoo and Microsoft for the specific SMTP settings of their services.
If you continue running into any issues, after confirming that you are using the correct settings, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
01-22-2019 01:13 PM
02-17-2026 12:32 PM
I had similar issues, this is how I got it fixed for my hotmail.
Set your SMTP port under network settings/ port number settings to 993
Set your Pop port number to 995
(both Gmail and hotmail support IMAP/Pop, you have to turn imap/pop support on in the sercurity settings of your email account. You also need to create a application password for what ever service you use, google that for how to do it.)
Then go to: Settings/Registration: Function Settings: TX Settings > Network Settings - E-Mail/I-Fax Settings
SMTP server should be smtp.office365.com for hotmail/outlook.com or office365 accounts
smtp.gmail.com for google.
email address is your full email address
pop server is outlook.office365.com for hotmail/outlook/office365 accounts
pop server for gmail is pop.gmail.com
POP RX set to On
Pop Authentication off
APOP Autentication off
SMTP authentication On
username: (your email address)
password (your password)
Use TLS for SMTP On
Verify certificate off
Use TLS for Pop On
Verify Certificate Off
REBOOT FIRST!!!
Then test it out.
