imageCLASS MF644Cdw Secure Print option not showing up under macOS Monterey
lingcherd
Hello,
I am setting up a ImageClass MF644Cdw on my macOS 12.4 (Monterey) machines. After adding the printer, and when I go to print, under Special Features -> Job Processing, I do not see "Secure Print". The only option available is "Print" which when selected, print right away to the printer.
On the printer web site, Secure Print is set to on.
Is there anything I am missing to get Secure Print turned on?
lingcherd
I just found out under System Preferences -> Printers and Scanners -> Options & Supplies -> Options Tab, the Secured Print option should be checked. After that the Secure Print option will show up under Special Features -> Job Processing under the Print window.
2 REPLIES 2
lingcherd
i know this is really old, but for some reason, even once i have this enabled, it doesn't show up as an option for me.
