IJ Scan Utility not showing option to scan both sides of document in ADF mode
aimxx
Until January 2026, my TS9520a showed the option check box to enable automatically scanning of both sides of input documents in ADF mode. The input paper used to be sliding in and out after each side was scanned. As of February 2026, the option has disappeared. I recently got a message to update my printer firmware so I suspect the update may have impacted this feature that I used to love
2 REPLIES 2
Firmware doesn't typically remove features.  Typically it addresses security vulnerabilities, and adds or enhances features and functionality.
Can you please tell us what is the version and build of the operating system you're using it printer with?
How is your printer connected and to what?
What software did you install with the printer?  Are you using Canon software to scan?  You can use the link below for reference.
https://www.usa.canon.com/support/p/pixma-ts9520a-wireless-home-all-in-one-inkjet-printer
aimxx
Thank you Rick for such a prompt response. My responses:
Can you please tell us what is the version and build of the operating system you're using it printer with? Windows 10 Home Ver. 10.0.19045 build 19045
How is your printer connected and to what? Via WiFi with all Canon Software and drivers downloaded from the official Canon site using instructions that came with the printer I bought November 2025
What software did you install with the printer?  Are you using Canon software to scan? As per the above, I'm using original Canon software including canon's ij scan utility
